1 - 2 of 2 Posts
I have a pair of Hertz 165's I'd like to install in my 2013 FLTRU. Question is can I hook this up directly to the stock radio without using an amp and have no issues? Is an amp required? If an amp is required which amp would be best? I'm only wanting more sound out of the front fairing speakers. Thanks in advance for suggestions.
Stock head unit is made to work with two ohm speakers. The Hertz are four ohm. You will also be underpowering them greatly. You want to get an amp. You are going to get 1000 different answers about amp choice so the search button would help you
1 - 2 of 2 Posts
