1 - 3 of 3 Posts
High beam indicator has started to come partially on and flickered. I dont notice any headlight flickering when it is doing it.
I just remounted the fairing. I slid the headlights in afterwards and dont think I have any wire pinching.
I do have the fuel moto led bulbs. Put about 4k on with them with no issues. But they do stick further our in the rear than stock.
Any ideas?
Put the stock light bulbs back in and see if the high beam light stop flickering, if it does then I would think that the new headlight bulbs may be the issue.
Discussion Starter · #3 ·
you are correct, I put the stock back in and no flicker. The led plug did not fit as snug as the stock, so I bent the bikes female contacts slightly so the leds plugged in tighter. That seems to have worked. Rode 4 hours, no flickering
1 - 3 of 3 Posts
