HI any info would be great thinking about lowers from HOGG CHOPPS
will they woek with a 21 inch wheel .
i think i read there might be a small problem because the fender is tilted back a bit to clear the wheel .
Don't know about the 21" wheel, but I liked mine. Easy to install and remove. I only used them in the winter time.
Thanks for the help , if
Any one could give some feed back co
about the 21 wheel working with the set up please post :confused:9
I've never seen em with 21" wheels. I have mine with 19" HD Agitator wheels and there is no problem.
If you do have to tilt the fender back for the 21" wheel it's less than 1/4", I'm sure the lowers you want aren't built so close where that amount will make a significant difference.
Sent from my SPH-L710
I ride with mine with a 21" and a 7deg rake in the neck. No problems, I love them.
