1 - 20 of 22 Posts
I've seen pictures of a single one mounted under the tour pak shining on the ground behind the bike. Looks like a better option.
Found on the internet Customize That Ride - Custom LED Light Kits some hologram lights for our rides. The only problem I see is that you have to make a big hole on the bottom of each saddlebag to install them.
The effect is kind of cool
I just ordered this set.
Hope they look like the photo.
I'll post up a review and photo when I get them installed.
Mike U.
I would think that a bracket of some sort could be made to bolt somewhere that way you don’t have to drill into the bags.
Reactions: Mike U
I just received a phone call from Steve at Customize That Ride.
Apparently, I entered my address incorrectly and he wanted to verify it before sending the lights out.
He was very personable and helpful on the phone.
I'm looking forward to getting these cool lights installed.
I'll keep everyone posted.
Mike U.
Mike U.
Let us know how they work out. Hope they look like the pic
I've seen them mounted on the bottom of the front down tubes on a bike at one of the local bike nites
I think a bracket off of the exhaust pipe mount could work. However, they look pretty deep. If they are too close to the ground the image would be really small.
Well I ordered these lights on Monday the 12th and they arrived today the 16th.
Now that’s what I call Great Service.
They came all boxed up and I can honestly say they are extremely well made.
I’ll try and upload some pics.
I’m looking forward to getting these lights installed.
Mike U.
I put some ghost lights in my bags a couple of years ago. Drilled holes in bottom of bags and wired to accessory switch. No issues with mounting; light sealed hole well.
Reactions: Mike U
Those look awesome Banshee!
I'm looking forward to getting mine installed.
Where on the bottom of the bags did you install them?
Mike U.
Drilled the hole at the back end, outside portion of bag just in from the back wall where the bottom flattens out. Then ran the wires over the little center hump in the bottom of the bag, down the channel that runs along the bottom and up the side of the bag. The wires are small diameter, so I think you could work them between the bag and front bag bolt grommet. But to simplify it I drilled another small hole close to that front bag Bolt just large enough for the heat shrink covered wires to fit through. I used a molex connector just outside the bag before running the wires on to my accessory switch connection. It’s an easy disconnect of the molex plug to pull the bags.
Reactions: Mike U
Thanks for the reply Brother.
I appreciate it.
Mike U.
Mike U.
He's an hour away from me...gonna have to give him a call and see if he can do a custom one.
Best of Luck Bevis.
Steve is a great guy in my book.
Give him a call and mention that you heard of him by me on Our Forum. I`m sure he will help you out.
Mike U.
1 - 20 of 22 Posts
