1 - 20 of 24 Posts
My Shark will be here in a week, and though I have read some comments, how does one plug in all their stuff on a Custom?
I will have a battery tender, I guess a standard Pig Tail adapter for that?
Next, a smart phone mounted with Ram X mount.
In the winter, I have heated gear. On my old bike, I have a battery mounted pig tail adapter for that.
I am contemplating mounting a Power Vision, and occasionally, I take videos with a Go Pro.
Now I will not be using all this stuff at once, but I can definitely see having a smart phone and heated gear plugged in while wanting to video with the camera and keeping it charged. The custom has one power port.
Any recommendations? They would be MOST appreciated!
I use a 90 degree cigarette lighter adapter I got off Amazon for cheap. It has 2 lighter jacks that I use that to power the phone and radar detector.
If you have gear that has a USB power cable, you can get a single or double usb port that will fit in your lighter/power point. Got mine at pep boys for a few bucks.
I wish I knew the best type to get. Also, I wonder if hardwiring to the battery for one line is a good (or bad) thing.
The smart phone and the Go Pro at least will have USB, don't know about the Power Commander. I know the heated gear does not. That may be best to the battery. Thanks folks. Anyone else (please).
Shark of the Month October 13
Use the under seat accessory connector for your electric riding gear. I believe there's also one inside the fairing. Go to Amazon and buy the repair manual for your bike, it'll pay off time and again, even if you don't do a lot of your own maintenance.
I have an extra power point & USB that is inside my right glove box. Frankie has an extra power point he put in his tourpack in case something needs charged while not in use. We both have heated gear that is plugged into a battery harness from Gerbings. They are only about 10 bucks.
Old School
Battery Tender pigtail for heated gear, iPhone charger with a usb plug piggy back in the power port ( cig Lighter) takes care of three at a time for me.
Hi Tracy. Does your heated gear have that round plug end? My HD gear (Gerbings) does. Are you saying that there is an adapter for this round plug to USB?
I saw those pics of the power point in the Tourpack, but this is a Custom and I do not have anything out back except a slipstream! Thanks!
This is the scenario I had in mind. I was just wondering if there was a better idea. I have heard of an HD under-seat multi-plug adapter, but I am not sure of what it does nor what the benefits would be. Thanks!
I dont know of any USB adapter for the heated gear. I installed the USB for my iPod.
You'll want your heated gear pigtail wired to the accessory switch thats on the dash(the connector that it controls is right under the seat, in a perfect spot to fish the pigtail out, to plug into your vest). It is super handy to be able to switch it on and off, right in front of you. The in line switches that the the heated gear companies sell, are a toatal PITA to use while going down the road. As others have said, the service and parts manual for your bike, are your friend. One of the very first "accessories" to purchase, IMHO. Your bike should have came with a battery tender pigtail already hardwired to the battery, I believe? Also, be sure all pigtails wired to the battery, have an inline fuse! Never wire anything to the battery, without properly sized fuse protection.
Enjoy your new scoot!
Jeff
Heated gears take too many amps for a USB... and most USB adapters drop the voltage to 5 volts I think that cell phones and ipods use.
Do the double/piggy back adapters that plug into cig lighter charge both items at once? When I plug in GPS and samsung smart phone it does not seem to charge both.
I've got the tourpak power point, and 3 more new ones sitting on the bench waiting for this winter's fairing removal. Intentions are to install 2 more power points, one in each of teh glove boxes, and maybe one more in the tourpak.
The Power Vision is powered by it's own cable that plugs into the ECM port, no other cable needed.
BTW, I bought a combo pack, cell phone charger which also came with a double USB adapter to plug into the power point. The cell charger works fine, but the USB adapter plug wipes out my radio signal every time I plug it in, even with nothing plugged into it.
The combo has the Duracell brand name on it.
iPhone charger from Radio Shack has a USB piggy back for charging two at the same time. Low draw, so I wired the power point constant hot.
Don't buy yourself the xgrip I think it is not solid it still moves after the smart phone is in already. I wasn't happy with it and I wound using the Iron Aces mount with the Motorola car dock. Look it up in my album.
Discussion Starter #18
Too late...I did already. Hope it works for me. Galaxy S3 with Otter Box Commuter case.
Discussion Starter #19
Quite correct. I forgot about the PV dedicated module. Thanks.
That is REALLY odd. It's weird stuff like this that I am trying to avoid.
Discussion Starter #20
This is a great idea of course, but I'm too chicken with a drill on the new machine...which I don't even get for another week!
1 - 20 of 24 Posts
