1 - 14 of 14 Posts
It always takes me some fiddling and luck to get my windshield at the perfect angle where all that madstamagic happens.
But then when I want to raise or lower the shield I, inevitably, end up loosing that sweet spot.
Does anyone else have this issue? And do you have a way to mark the brackets so you know exactly where it's good?
tl;dr: hometoast has an issue finding and staying on the sweet spot. :eek:
I set it and forget it. If needing it higher is the issue how about a taller shield to just swap??? Shorter for solo and the Taller for two up?
I mark the bolt holes with a black sharpie. I raise and lower mine in te city sometimes when it gets hot and I need some air. I have found once you find your angle the height of the shield doesn't matter too much. I guess I have a big sweet spot
but another shield so I don't have to adjust my adjustable windshield? heheeh
True; I don't have to move it a whole lot, but when I do, I have to start all over again. You can see the black sharpie on the black brackets? I'll give that a try.
for tilt I use an app on my phone called TiltMeter. I know my sweet spot is 57 degrees and then raise up and down depending on need.
I marked mine by buying a '15.........:D
Sorry, I just had to bust on ya....! Don't hate! LOL!!! :D
I always just adjusted mine on the fly. I guess that isn't the safest way, but I ride hands free a lot.......
I have my old one for sale if anyone knows anyone who needs/wants one. I'll make 'em a good deal
Thanks all. I forgot I could use the phone to get a reading and use that.
Simple. Measure distance from top of radio housing to top of windshield.
I use a 360 app on my phone which is a digital protractor. Simply lay it on windshield and adjust tilt. My personal sweet spot is 9 inches at 61 degrees
Easy to return after adjusting for whatever reason
Mine is full height for two-up riding and lowest for in town riding and I always leave it at the steepest angle.
I also marked my brackets w/ a silver sharpie. Easy to see the lines . .. . but I've never moved either since I set it there. If I ever fiddle with it or bump it out I can get back to my spot easily.
"Protractor 360" APP.... for IPhone
58.... I set so I can look over and the ground 25 feet ahead of me. (nose height) Loosen and pull up without tilting if you want to shoot the air over your passenger. I add 6 degrees 2 up to 64. It works well for me
1 - 14 of 14 Posts
