How screwed am I?
4 reading
689 views 20 replies 10 participants last post by  Headrope
#1 ·
On a scale of pfft to new wheel needed, how fucked am I?
I’m guessing I need a new front wheel and bearing spacer?
#4 ·
The wheel itself seems fine but the damage is where the bearing seats, which looks to be part of the wheel that I don’t think can be replaced. Can it? Chronologically I had a humming noise coming from the wheel. Removed the bearing and saw this. So unsure how it happened.
#6 ·
Being that it's a 2010, you should be able to find a take off wheel very easily and for cheap. I wouldn't even mess with that one personally. Swap the tire to the new wheel and hang that one on the wall as art. I'm pretty sure I have a spare axle sitting around from when I had a 2010 SG if you need it. I can take a look, just don't tell anyone that I used to ride a SG. ;)
#16 ·
Technically speaking, the bearing sits in that housing. The axel goes through the inner race of the bearing. The bearing housing that actually captures the outter race of the bearing seems to be ok. I am doubtful, the way it looks, that you would get much movement out of the bearing, thereby the axel as long as the bearing "seats" inside the housing correctly. BUT, I would be nervous AF any time I hopped on that bike. You probably would never have an issue as long as whoever put the tires on always made sure it was balanced to compensate.
I've seen this done more than once from someone trying to "knock" a bearing out of a wheel. Shit happens.
That being said...What year is the bike? Where are you? I have a set of wheels I pulled of my 12 Ultra that have been sitting in my basement for MANY MOONS.
#18 ·
The puller I used sits inside the bearing and doesn't go into the spacer but I bet you're right. Previous owner might have been crafty with it.
I've removed the wheel before but not the bearing until now so it was a ... nice surprise. Appreciate your offer on the wheels but am looking locally(Washington state). Looks like a good deal though. Folks, check that link out
