How To Fix TBW Issues After Internal Wiring
172402 Views 165 Replies 69 Participants Last post by  Stevenoxious
2
Ok so I personaly have experienced many hours of frustration and anger dealing with the TBW and wiring my bars internally. I have heard of several issues people have had and have experienced a few on my own. I am going to list a few common issues and how to fix them, and then I have also included a write up on how to hard wire the TBW and elminate the connectors.
Cruise not working= either one of two things. 1) Your brake switch is broken from not shimming the brake lever out. The brake switch is a little plunger between the brake lever and the master cylinder. Squeeze your brake lever and you can see it. The bike thinks the brakes are on, and therfore the cruise will not engauge. 2) TBW green connector inside the bar has a weak connection. I had this issue during the pulling of my wires though the bars. I pulled the green coonnector out just enough to make it lose connection for cruise to work properly. Either tape the green connector very tight or shrink wrap it. The other option is to hard wire... write up is at the bottom of this thread.
Brake lights stay on=
The brake switch is broken.. refer to the above explanation.
Bike feels slugish/no power band/will not rev very high in the RPM range= TBW has loose connection or poor connection. Either tape the green connector very tight or shrink wrap it. Neither is guaranteed to keep it connected but it might work if there is enough room inside your bars. Or you can hard wire the TBW... keep reading for the write up.
Twist the throttle nothing happens, bike just idles= The grip is not seated completely on the internal gears located on the inside end of the grip and on the end of the TBW sensor, OR, the TBW has come apart and has no signal. Either tape the green connector, shrink wrap it, or hard wire.
Check engine light on= Run the diagnostics ( there is a thread in the trouble shooting section on how to do this) I am willing to bet one of these code has shown up:
P1510 - Throttle actuator control limited performance
P2127 - Twist grip position sensor low/open
P2138 - Twist grip position sensor correlation error
The problem to all of these is the green connector it loose and it is not getting enough (or no) signal to the TBW sensor and the TBW sensor cannot send anything to the ECU. Again either tape it, shrink wrap, or hard wire.
Now on to the write up:
After having some of these same issues on my bike after I wired my bars internally, I knew I had to find a better solution. So once again I tore the bars down and pulled out allof my hard work in pulling wires, and started over.
My bike first had several throttle issue which I originally though was a loose connection on the TBW connector in the fairing. I could move the TBW inside the fairing and make the twist grip work correctly... then I would move it some more and my bike was sluggish, and would not rev past 3100 RPM. Then the cruise quit working! So I took another forum members advice (can't remember who exactly it was but, you know who you are) and decided to hard wire the TBW and elminate the green connector.
First I took the bars off the bike. Then I took the big switch housing connector apart again, and pulled the switch housing wires out of the bars. I had to do this because the TBW was in there so tight I did not want to damage it anymore than I had to. When I pulled the TBW harness out of the bars, this is what I saw:
Not pretty! It looks like the inside of the bars has teeth!!! Thats two layers of electrical tape that the bars chewed up from pulling them in and out of the bars. I didnt find any huge cuts or nicks to the wires but the isulation on the wires was scratched pretty bad. Check your wires very carefully to make sure nothing is cut or nicked down to bare wire. Bare wire could cause the wire to ground out on the inside of the bars and short out, or blow out your TBW sensor.
See less See more
Reactions: 2
81 - 100 of 166 Posts
Donk, thanks for both of your writeups! The install thread was great and you saved me a ton of time with the FBW solder decision.
Looking good Bro! What bars are those? Glad everything worked for you.
Issues
I just finished installing some PY 14" bars. I am now getting error P2127. Is there a way to test if the wires got cut during the pull without removing them from the bars? The great plug has been eliminated already.
Bad news is, unless you know alot about back probing, which I do not recommend doing, then you have to take the wires out for inspection.
You might want to check the code first and see what it says first before pulling the wires. That might help narrow down your search for the problem.
P2127 = TGS2 low or open. I don't know if this picture helps this for the 09. I would start with what you changed out for an open wire.
Sent from my MB860 using Motorcycle.com Free App
See less See more
P2127
So do you think I may have messed up the re-wiring? My bike is good up to about 3K rpm then cuts out. Would the bike start if I had a couple wires backwards? Or is it more likely a loose connection or cut wire?
I installed bagger nation 10" monkey bars, and ran into the same problem, after destroying the insulation like in your picks pulling like crazy, i to cut the green plug out and soldered the wires back, wish ik the black plug was an option tho, i used welding write to pull my wired thru tho, nice write up
Vibration at 3 grand probably causing a short in the bars
Errors
So I pulled the TBW out and ended up having a broken Red wire. So I soldered in a new one and re-pulled etc. put it back together and now I have P2122, P2127, P1510 & P1512. Any idea what these are?
The P1510 definitely deals with the wiring of the TGS. I had that problem when I wired mine. I removed the wires, checked everything, removed the green connector on the TGS and wired it direct, the reinstalled and it was all good. I suspect that that you need to pull your wires and really check everything.
Done!
So I pulled it all ack out and it was too bad. I checked it out prior to pulling it through and was good to go. On my 3rd time pulling the TBW it went smoother and it is all back together and works! Thank you all for the advice. FYI there is another tread by Ironrider that has all the error codes.
See less See more
Great job on the write up and Thanks for sharing
Seriously this write was one of the best. I am wiring my new bars and my tbw connector came apart. I didn't want to chance it so I cut it completely off and soldered it just as you showed us. Thank you very much.
Thanks for this write up, I did a bar change and ened up with P1510, P2138, so good by little green connector thanks to Donk, while I was at that, I said what the heck and internal wired my bars, put Krome Werks Heritage Stretch bars on, instead of taking the connectors apart, I cut and soldered the wires, I cut the wires about 1 inch different so the wires would tapper down to 1 wire, taped them up and pulled them with a 1/16 x 36 tig welding rod, went thourgh like grass thourgh a goose, the bars look great and it was not hard at all, just takes some time. Thanks again to all. Its nice to do my own work, not just the money saved, but to really get to know my Roadglide, and be able to say I did it.
Ya, and you know it's done right.
There is a little black plug in. I cut it off and used the hot connection for my Heat demons. if you go back through both of my handle bar install post, you can see where I pointed out those wires, and how I cut them off.
Donk, great write up, as far as the Heat Demons, by eliminating the green and black connectors, where you able to install the Demons without boring out the right grip to 7/8", and did you do a write up on the Demons?
I never did a write up on the heat demons.... wish I would have cuz they were a pain, and do not work that great. They are better than no heat, but they could be better. I did not ream out my bars and should have like they said. I had to cram them in the bars, and I am always worried they will crack or break one day.
I just put new Wild 1 wo577 on my trike put the new TBW in but now for the last three nights I road to about the same place and I get the engine light and the trottle will not work then it starts working again and I can drive it back home need help
Did you get rid of the green twist grip sensor connector in the handlebars when you rewired them? That connector seems to cause lots of issues.
After five trips back to the dealer for TBW issues. I finally got up this past saturday at zero dark thirty and removed the green connector and soldered the wires per Donk's procedure. Over 150 miles later, no uncommanded full throttle. no limp home mode, no codes and no check engine light. I think the 011 RGU just might be safe to ride now. Procedure wasn't difficult to do at all. I have no plans of ever changing the bars, so hopefully I'm good to go for the next 100k miles!!! :D:D
Wow looks like lots of folks are having nightmares with that green plug. I guess a public service announcement is needed:
SAVE YOUR SANITY, CUT THE FREAKIN GREEN PLUG OFF!!!!!!!!
Okay, now everyone knows.
Glad to hear everyone is doing this project themselves, and it is going well. Thank for all of the feedback.
