Need to fix the picture issue. Says third party images are disabled.
Help!!So I put 14" apes on this weekend. First issue was there was no throttle when twisting but I found a black wire that came out of the connector and fixed that. But now I have no cruise control, and my engine light is on. When I go through the diagnostic for the cruise everything turns green indicating it is working correctly. The codes are P1510 and P2138 with a part # of 001349-01. Someone told me to check continuity of the wiring but how do you do that if you don't have access to both ends of the wire?
JB, since the cruise control function is operated by the left hand control switches that's where you start. Any way you look at this it's going to require some work.Help!!
