1 - 3 of 3 Posts
Is there a trick to installing the stock header? I have trouble getting the lower mount flange on the pipes to fit under the mount on the bike.
I have tried lining up the ports first and when swing the pipes down, the mount will not clear the flange. If I do front port then the lower mount, I can't get the rear to clear the fins. Same with trying rear first then lower mount, can't get front to clear the fins.
Thank you for any assistance.
I've removed many stock headers and always found the placing the rear in first and then pushing the front in works. Line up the pipes and they'll go on.
Thank you for the response. 1 question. are you lining up the lower mount on the CAT after or before the front pipe? or before the rear?
I have 2 stock header units and both give me the same problem, so I don't think its the pipes.
1 - 3 of 3 Posts
