Hi. What is the procedure for reading historical ride information? Does the TMax not store this information between rides?
Banned
Runt the auto tune feature. You can see his many points you've hit on both cylinders and his much changes if made percentage wise if you don't run the auto run command before you look the "detail" before running autoemap.
If you are looking for RPM and Heat Temps, look under module configuration, then warranty information. At least that's where it is on the cable throttle version. You can export the data to a spreadsheet. You may not be able to see it if your font size in Windows is set to anything other than 100%.
I'll try that. Thanks for your help.
The RPM and Heat Temps are running totals, so I created a master spreadsheet and just add another column whenever I hook up to the TMax. That way I can see what numbers changed since the last download.
That works. That's handy information. Looks like I spend most of my time between 2300 and 2800 RPM and head temp averages between 235 and 265 degrees.
Thanks for the help.
