I got the woods tw6 cam installed in my 2010fltx. The Dyno results were 80/91 all charts I've looked at suggest I'm 10 hp/tq low. Has rhinehart 2n1. Exhaust .any suggestion on what to check is appreciated afr is 12.8-13.2 thanks duane5157
If you have no idea what you are talking about, maybe you should not talk about it.He has a PC Vision tuner, whatever that is. This is why I went with a quality dyno tune. No guessing.
Ed's as good as they get. When you get a quality dyno tune from a competent tuner there is no guess work. People that run auto tune tuners instead of getting a good dyno tune seem for the most part to be satisfied. You don't miss what you've never had.If you have no idea what you are talking about, maybe you should not talk about it.![]()
Nothing wrong with Powervision tuner. When I mentioned competent tuner I was referring to the guy tuning the bike on the dyno. You ended up at 85/91, if this is a 96" motor I don't think you're that far off. Most 103's with cams end up in the 90's hp wise and 100 to 110 tq with 7 more cubes. I'm not an expert on cams by any means but if I remember correctly I think those two cams like around 10/1 to shine. Check with Bob Wood on what the best comp is for those cams or even Scott from Hillside here on the forum. He does lots of Wood cams. Hope this helps.The PC Vision is a quality tuner and the bike was run on a dyno,hence the dyno sheet also you can see the correction to the afr to smooth out the pull. The question still remains, do you think this cam needs more compression or does the hp and torque look close to what it should be based off of other dyno sheets with that cam. Duane5157
????Ed's as good as they get. When you get a quality dyno tune from a competent tuner there is no guess work. People that run auto tune tuners instead of getting a good dyno tune seem for the most part to be satisfied. You don't miss what you've never had.
I think I've discovered your problem.it has a PC vision, 2n1 rhinehart,big sucker intake filter, Dynoed at the local Harley shop. Im thinkng I might be a littlow on compression.
I read it as he used his tuner to install a canned map and did a dyno run at the dealer to see what the effects were, then asked questions about it.If you have no idea what you are talking about, maybe you should not talk about it.![]()
But you said this;I read it as he used his tuner to install a canned map and did a dyno run at the dealer to see what the effects were, then asked questions about it.
Hands up people, this is a hijack!But you said this;
"He has a PC Vision tuner, whatever that is. This is why I went with a quality dyno tune. No guessing."
I don't see any questions, did I miss something?
Are you saying that you couldn't figure out what he meant?
