1 - 4 of 4 Posts
YouTube "Harley ignition switch removal on street glide". He shows you how to remove and put back on. I use it every time I need to do something.
Its not clicked in properly. I had this happen to me two weeks ago. Put it all back in till it clicks and then reach under and feel that push button. If it isn't fully extended, jiggle it a bit. Mine got stuck so I sprayed some wd-40 and worked it in. I think they can bind since its not a part you regularly use.
Sent from the roadglide.org Monarch's phone
Thanks for responding guys, the problem was a little tricky for me. I ended up having to pop the little sticker of and tightening the torx head screw, it was loose and that's why it would wiggle loose and pop off. Headache dodged!
1 - 4 of 4 Posts
