1 - 14 of 14 Posts
Anyone else have issues with the tumbler lock turning, mine isn’t very centered and a PITA to turn 99% of the time
415798
Sometimes I have to wiggle the bars to get it to unlock the forks and I have to push down hard to lock it.
Locking it is usually my issue. Even holding it down with 1 hand and trying to turn its still tight.
Had that issue with a used bike I just bought. A drop of lightweight oil fixed that. I see your bike is not very old though. Can't hurt to try it.
I tried WD-40 on the key. Can’t hurt to try something thicker
WD40 or cable lube in the barrel, that's where it will do the most. Wrap a rag around the switch housing to protect from overspray. After a minute to soak in, work the key in/out and lock/unlock. You may have to wiggle the switch housing to get the lock to engage.
I do sometimes, mostly when unlocking though.
With every oil change I do on a bike, be it mine or others’, I use graphite powder on the key and squirt some in the locks....I do ignition, saddlebag locks, tour pak lock, and/or fork lock depending on the bike I am working on. I then work the key back and forth in the lock. This keeps everything up to snuff.
I had that problem with my 10 when I first got her, and it drove me nutz for months. I finally said fuck it and put a squirt of WD40 in the lock barrel, and it's been working fine for the last 7 years now...so I'm guessing it okay.
Note: I live in Florida, so she sees a lot of rain.
Reactions: jstucker1976
Going to pick some up today and add this to my maint. routine
Check your key for any slight burs also....
you mean, like actually following the maintenance recommendations in the manual? gasp!!!
Reactions: RGKen
had mine get hard to unlock on my covid19 trip, was 1700 mi away from home in a small town with no dealer. short panic attack then wiggled the forks and it unlocked. had it happen couple times after but is workin fine now.
1 - 14 of 14 Posts
