1 - 4 of 4 Posts
i have a 2002 road glide that needs a new in tank fuel line going from check valve to fuel pump. Harley wants 58.82, what a rip off. does anyone know how long the fuel line is ? (check valve to pump)
J&P?
A friend of mine just replaced the fuel filter in the tank on his 05' Springer Soft Tale. I looked it up for him in J&P catalog, it came with the FF and the line and was around $50 bucks with shipping.
Check ou J&P.
Good luck!
HSP
thanks, i cannot believe Harley does not just sell the hose by itself. ill keep looking and if i find something ill post it here for all to read and save money.
Filter Change
With the age of your bike you might want to change the filter inside the tank as well. And be sure to replace the canopy screws with new ones. There is special sealant on them and the old ones are likely to leak if reused.
Also slice the old fuel line length ways and secure it around the new one with zip ties. That will keep the new one from wearing holes in itself from abrasion. That was a common problem with the fuel lines.
1 - 4 of 4 Posts
