1 - 2 of 2 Posts
I disconnected the battery in order to have the cluster above the switch to gain access to the handle bars bolts, I just needed a little adjustment done, once everything was reconnected and ready, the infotainment is not starting, I removed everything actually hoping i had missed a cable or something, nothing, everything in the right place, any ideas, I'm going crazy over this one.
Push the bottom button on the right, should fix you up.
1 - 2 of 2 Posts
