Doc.....I've had no problem at all with a heat issue on my leg or my girlfriends leg with Fuel Moto's head pipe. Heat issue went away or is very tolerable now.If I were to change the headers, I would go the Full-Sac route. Ceramic coated black inside and out, less heat on your leg. Doc
I think I'll be buying one of these head pipes in the next couple of weeks .I already have the stage one A/C and Rinehart pipes on. What computor setup did you go with ?
I might end up in the same fix in order to preserve the extended warranty easyrider and I live in FL so it's a looooooooong way to Jamie. Damn. I wonder if there's a way to email a SERT tune.I went with Harleys SERT tuner. I had the local harley dealership install the headpipe, Vance & hines Hi-outputs, along with a set of Woods cams. The dealership would only tune with a SERT tuner. The tune from the tech at the dealership was terrible. the bike would stumble or be totally flat under 2500 rpms. A week later i stopped back at the dealership and talked with the tech to see what could be done with the tune to get it to run better. He couldn't offer any explanation or suggestion to improve it on how it was running. So, I made an appointment with Jaime at Fuel Moto and he retuned about a month ago. Runs like a champ now. The hp. and torque numbers ar e where they should be.
I've read alot positive results with TTS tuners and Power Commander V tuners along with Harleys SERT.
It would be worth the call to talk to Jamie about your situation. Your right it is a looong way up here and the weather is just starting to feel like fall here...before we know it.....snow will be falling....I might end up in the same fix in order to preserve the extended warranty easyrider and I live in FL so it's a looooooooong way to Jamie. Damn. I wonder if there's a way to email a SERT tune.
Mmmmmmmm - maybe a call to Jamie is in order.
