1 - 13 of 13 Posts
Going for outer fairing paint...while having it painted was going to paint the inter too...is it flat black or semi gloss black....thanks..
If you are painting the outer, why not have the inner painted as well??
Agree - paint it to match the outer (like mine), or some have chosen a neutral contrasting color for the inner fairing. I have not personally seen any contrasting other than picts.
Hammer-rite flat bkk (sp), scruff, hang it spray it, let dry above 65 degrees, then hit again, admire and install after a satin coat if you want is what i've done, covers off and separate looks best, make sure it looks wet when spraying, don't run it though. And don't huff to much either:eek: carry over to the inside edges sharply
Inner fairings are NOT bare plastic, they have a low gloss paint coating on them.
Scuff with gray scotchbrite, clean with wax and grease remover, epoxy prime for best results then base/clear your favorite color.
I often wondered this. Thanks for the info Road Hawg.
I'd love to have some stuff painted, but I picked the paint that apparently has to have gold and diamonds mixed in. At least that's how it's priced LOL
Thanks for all the info...mine is an '03 ..it has faded over the years...the dealer said that it is not painted and you need to get a new one...i think simi gloss will do the trick..thanks
Man ain't that the truth. Taking mine to the painter tomorrow, gonna have more in buying the paint then I am in the painter.
Some dealers are so funny that way, of course he is going to tell you that ;)
1 - 13 of 13 Posts
