1 - 4 of 4 Posts
Just double checking before I make a mistake.... The TBW does not need the 2 wire black connector harness..... That is for heated grips?
The green connector is needed for the TBW?
food for thought....when I did my bars I extended the wires so that the green connector is outside the bars in the harness in the fairing. That way if you have to remove the bars it is easy to disconnect.
1 - 4 of 4 Posts
