I attempted to run my Twist Grip Sensor wire through my new FMB 10 inch apes last night. It is obvious to me the Green Connector will not make the bend at the meat hook.
Proceeding forward, I purchased the SE Twist Grip Sensor. Tonight I may attempt to de-pin the stock connector and run the wires again. If they appear to be too much of a pain, I will install the SE Twist Grip Sensor.
So - When I go to internally wire the Twist Grip Sensor and later (or now) the left and right sides control wires (signals, cruise, audio, etc) I may need some type of lubrication to run the wire bundles.
What type of lube has been used for assisting with the installation of the wire harnesses internally to the handlebars?
# WD40?
# Axle Grease?
# Vaseline?
# KY / Astro Glide?
# Other?
Thanks in advance,
Jim
# WD40?
# Axle Grease?
# Vaseline?
# KY / Astro Glide?
# Other?
Thanks in advance,
Jim
