1 - 4 of 4 Posts
Looking to add some Apes (haven't decided which ones yet), but would like to find the best way to do it. I installed Apes on my RK and cut all the wires to extend them. I perfer not to cut, but would like to add wire extentions any thoughts/pictures.
on the 2010 FLTRX, there is no need for wire extensions as you have a ton of it under your fairing. There is enough wiring under your fairing, to have at least 25" apes I would guess. At least enough to wire another bike,.. :) Its a lot!
The only things you have to worry about, are the front brake line (which actually runs back to under your right ass cheek,.. at least if you have ABS) and the clutch cable. Both of them have enough slack to have at most 15" apes.
have you seen what Yaffi did?
Hay Neano62, Paul changed bars and does not offer them for internal wire.
Great just when I made up my mind. Do ya think I could drill them myself?
I was going to take a ride down and pick up a set, now I'm trying to talk with someone, plus side is they dropped price to 199. PM me I'd like to get the specs. you have for wire setup.
Thanks, Frodoe
1 - 4 of 4 Posts
