I want to run some extra power up to my fairing.I want to come off the battery for it.Is there any harm in unhooking the wires from the battery ?
It should be no worse than changing the battery. You'd have to disconnect the battery terminals in order to remove the battery which would mean theres no power to any of the wires on the bike.
If you have the alarm siren, turn ignition on with fob present, then pull the maxi fuse to disable the alarm. Then you can disconnect battery.
Also, make sure you fuse the wire you install as close to the battery as possible.
As Psycho said, neg 1st, good ins when removing fairin, inline fuse any n all when going direct to batt
