Looking for a stock "whip" antenna and antenna-to-cable adapter. I don't need the bracket. I was using a hidden antenna in the fairing, but the amp install ruined that.
What year of bike?
It's a 2009. The PO removed the stock cable and installed an extended one with a wiring harness for the quick release tour pak. The pak has antennas but I only use it about once a year.
Go to AutoZone and buy the small rubber antenna with the wire that comes with it. Then zip tie it under the fairing or hot glue it to the inside of the fairing itself just under the windshield. Works good.
