Wood Bicycle part Road surface Gas Circle
Bicycle frame Bicycle handlebar Bicycle tire Bicycle fork Automotive tire
Bicycle part Tool Hand tool Gas Metalworking hand tool
Scaled reptile Automotive exterior Snake Auto part Metal
Automotive tire Asphalt Road surface Wood Gas
I have a Fuel Moto stainless header for a twin cam came off my 2015. It is in great shape. Buyer to pay shipping
Jackpot 2/1/2 head pipes are the highest quality, best performing head pipes on the market. Designed specifically for the performance and tuning characteristics of the twin cam engines these 2/1/2 head pipes provide proven performance gains with a broad torque curve other pipes simply cannot match. The Jackpot 2/1/2 features full stainless steel construction, dual 12mm & 18mm O2 bungs (plugs included), cnc mandrel bends, and each pipe is completely tig welded by hand, a true hand build work of art. The true standard for quality and performance.
Jackpot 2/1/2 head pipes are also available with an optional multi process HTC Ceramic interior/exterior coating for maximum heat reduction. This is an absolute top shelf coating and is a proprietary offering from Fuel Moto.
Beware of imitations and demand the best!
  • 304 Series Stainless Steel construction
  • Dual 12mm & 18mm oxygen sensor bungs to accommodate stock and wide band O2 sensors.
  • Exclusive "Tandem-Flow" large diameter merge collector design to allow maximum flow and convergence.
  • Retains factory heat shields & factory cross-over (full sized Jackpot X-Over is compatible).
