1 - 3 of 3 Posts
What is the best pipe to run on a 117ci twincam custom build engine? Jackpot XXX pipe or Dragos H-pipe? I want the best performance out of this setup. Please give me some examples of big inch engine builds with these two pipes. I'm getting ready to pull the trigger on a pipe and don't want to make an uninformed decision.
Thanks for your help.
Kelley
Nothing to do with the 2 pipes you are asking about, but if I put a built 117 incher in my scooter frame it would be puffing fire through a D&D Boarzilla.
EFI tuning and Exhaust Expert
Kelley
You are really comparing apples to oranges with the two pipes are you are comparing. The Jackpot XXX has tapered primaries with a large profile merge collector and is designed specifically for larger hi output engines, the other pipe is a true dual style with an interconnect which would be best suited to stock or mildly modified engines.
1 - 3 of 3 Posts
