not sure if this is helpful
I know these guys, doesn't mean all there stuff is amazing or super perfect
seems like a easy way to correct the bike after monotubes or air ride
>$20 shipped
this method would be one step up from using spacers or washers - save ya $200 over a new jiffy stand
I use one of those on mine, worked perfect to correct the stand angle after I loitered mine 2”
I don't believe those will work on the 09 up. The floorboard is mounted thru the jiffystand mount.
It will, the 08 mounts through thejiffy stand also. The kit comes with a spacer to move out the floor board. It moves it out about a 1/4”
Who makes it. Website?
If you cursor over the original poster image it will take you to a link on e-bay.
It is made / distributed by BK-Rider.com.
Good quality. The only problem I had putting it on was my spring came loose and it is a PTIA to put back on. There is a technique for that too like all things HD. I stretched out 2 springs putting it on, (stretching them out must be a common problem as my dealer actually had them in stock) I then went to Lowe's and bought a spring that fits perfectly and a easier to put on and doesn't stretch out.
