1 - 2 of 2 Posts
Did you check the hook up with the Aquatics 5BT-H yet?? I talked to tech support at Aquatics and they said the RCA outputs should work and I should be getting sound using them.
He also mentioned that I could test the amp by using a 3.5 mm to RCA plug adapter and plug that into my MP3 player then plug the MP3 into the amp. If I don't get any sound using this test then the amp is bad, if I do get sound then the Aquatic 5BT-H is bad.
I am on a road trip right now so I will check that this weekend when I get home.
JMJOHN
ironmark ,,,,,
yes ,,, the test procedure that the J&M Tech gave you over the phone for the amp is correct ,,,,,,
I just ran the full test of the Aquatics 5BT-H replacement Harley radio here at our R&D shop in Tucson ,,,,,,
I have now configured all J&M ROKKER/Performance series amplifier tuning profiles for this radio ,,,,,
I must say that I am initially very impressed with the unit, the responsiveness of its handlebar controls, and the LOW distortion levels, even when turned up to maximum volume ,,,,,
for those who need the J&M ROKKER amplifier DSP download for this new radio ,,,, send email to [email protected] ,,,,, with speaker impedance information both front & rear positions,,,
1 - 2 of 2 Posts
