Finally decided on a set of speakers and got some Polk Audio DXi651's. I know I need some adapter rings. I currently have some 5X7's in the fairing. I tossed the stock speakers and mounts. I'm looking at the rings on eBay and one page says I need to get some H-D speaker grills again. Is this true? Can I just get some adapter plates and call it good? Thanks for any help!
SB, check out hawgwired for grills. I am not sure if they carry the adapters. What mounts did you throw away?
I threw away everything stock. I have Hogtunes 5x7 speakers and their grills in there now. I'm just wondering if I need the stock speaker mounts again?
I will check out Hawgwired though. Thanks.
SB, check out hawgwired for grills. I am not sure if they carry the adapters. What mounts did you throw away?[/QUOTEJ
Just checked out their page. Looks like all I need is a set of their rings and I'm good to go. Thanks for pointing me in the right direction.
Correct me if I'm wrong, but you threw away everything? Your gonna need the stock speaker adapters for after markets to attach to. You'll also need the oem adapters for the grills. Unless the Hogtunes 5x7's adapter bolts to the oem adapters. Post up a pic of what u have.
Okay, I'll get a pic up later. Maybe tomorrow. Gonna sleep after work, then ride later today.
