Does anyone have the KW extended heritage bars? Did you need longer wires, clutch cable, brake lines? I have the standard heritage bars and I need a little more. It's true, go 2'' taller than you think you need. Thanks for any advice you might have.
All the stock stuff fits, some of it has to be moved slightly and the clutch cable needs re routing a bit. Close, but it all works. These bars work very well for me.Does anyone have the KW extended heritage bars? Did you need longer wires, clutch cable, brake lines? I have the standard heritage bars and I need a little more. It's true, go 2'' taller than you think you need. Thanks for any advice you might have.
