1 - 20 of 30 Posts
Absolutely. That was the very first thing I did when I got my bike, and worth every penny!
Absolutely. I put them on my 2010 - but only on the right side to get my leg out past the heavy air breather. Weird thing is it doesn’t feel off or look strange. Nobody would even know by looking at it.
Yeah they did......with my size 13's....I wish I could even get more. But that wouldn't be conducive to going around corners with any kind of speed.
It looks comfortable but im concerned with the shift placement. The lever already seams too far in for me as is (i shift my foot inbd every shift instead of being able to make it from a natural position). Any way to easily move that lever over a bit for this mod? I dont use the heal shift at all and honestly thought of taking heel shift off and installing toe shift lever in its location to move it out more on stock floorboard location
I haven't bought these spacers but i may after reading this.
I actually did remove my heel shifter and move my toe shifter out and it works great!
Funny, I just replied in the “what did you do to your Road Glide today” section. I installed mine yesterday after procrastinating for several months. Huge difference. Feels like I made the entire floorboards wider! Highly recommend.
You can move your shifter out, I bought a spacer on line when I took my kicker off. I do not have the floor board extenders but they are on my short list.
I put them on in the first month I had the bike. Never regretted it, never needed to relocate the shifter. It's still right there.
I’m trying to decide if these extenders are just a tall-guy accessory? Some of this appeals to me, such as getting my foot/leg further away from the heat, and certainly relaxing the hip joint. At 5’7”, are these recommended? If they affect the toe shifter position, do they also affect the rear brake pedal position?
They do not affect the toe shifter position from what I can tell. Just push the floorboard away from the frame a little more. For those of us with splayed hips, a little more width will be more comfortable. Shifting will require the same motion as before.
The best thing about the extenders is it gives your feet a more comfortable position if you ride with your heels on the footboard and toes on highway pegs. I wear size 11 boots and without the extenders my heels would be just on the outside edge of the footboard when putting my boot toes on the highway peg. With extenders my heels are more toward the center of the footboard.
Question, do they make the floorboards drag at low speed U-turns or high speed cornering? I have tendency to scrape a floor board or two when slow maneuvering and in some cases switchbacks. I haven't read anything negative. the difference looks like they will make for a more comfortable ride. Thanks for any information.
Discussion Starter #20
I guess if you push it hard enough they will scrape, but i do no think they increase that by anymore. Now if i could find away to relocate my kickstand a little because i am scraping the hell out it.
1 - 20 of 30 Posts
