1 - 15 of 15 Posts
I have a set of Kuryakyn Kinetic black grips with throttle bosses. Less than 500 miles on them. Great grips but just not for me. They looked great on my ‘16 RGS with 12” Vindikta Marauders. $142 new retail. $80 plus the ride from 82801, OBO.
Another bump, price drop to $70 plus the ride. Would like to sell here rather than the online auction.
Does the left side (clutch side) glue on or is it held on by the controls like the harley grips?
I have the same setup but the ISO Kuryakyn grips and I have never needed to use glue
It sits just fine if installed correctly
These grip are great and feel great in your hands
That's a fair deal as well at that price
Just my .02 cents
Swomack
Just my .02 cents
Swomack
What is your method for install of the iso grip clutch side?
I have used windex in the past on a metric bike on the throttle sleeve
I’ve always been able to slide it on and tighten everything done
If I torque it up or down with my left hand it will move but it’s a good tight fit without glue
Because I use the throttle boss units on both grips for my palm to rest on I like it to be adjustable some
Once again it’s a tight fit because of the rubber seeded in the housing
Now if I was going to apply glue I would take some steel wool and make sure the glue had something to grab onto
Fresh powdercoated doesn’t make for a perfect bond
I have used the same style ISO grip on my last four bikes and only glued the first set down
If you get a pair try it first on the throttle side and tighten down everything and you will see what I’m talking about
Also always remember, if you are going to set up with glue, always apply the throttle side first
Electronic throttle so it dictates the left sides position
Now match up with the throttle side to the right side and your good to go
Swomack
Are these still available?
I have these same grips and they are great.... I didn't glue them either after I ruined a pair of ISO grips that the dealer put on my factory set of bars. I simply wrap some electrical tape around the bar to give it a little extra thickness and then spray some windex and they slide right on. Once the windex dries, the grip is very solid and isn't going anywhere unless you really crank on it with all your efforts.
1 - 15 of 15 Posts
