It looks like it's my shifter seal that's leaking. I pulled the snap ring and the washer, but I'm not seeing any seal in there. Does something else need removed to access the seal?
I don't have my seals yet, the ups guy should bring them tomorrow. I have a main shaft seal coming too. I'm planning to pull the sprocket to look at it, but I am thinking the shifter shaft seal is the culprit. Also replacing the other seal on the back of the primary.
What do you think? Worth pulling the sprocket just to be sure?
