1 - 3 of 3 Posts
2021 RGS
Hello everyone. Need some ideas here.
I recently purchased the roadglide LED kit from Member here, pmlightglide.com.
Last night spent hours installing, got everything connected, put the fuse back in bike, hit switch, and nothing. Not one of the led's even blinked.
Double checked all connections, in line fuse, and bike fuse. Wires from LED's are connected to spring terminals. There is a toggle switch to turn lights on with an in line fuse.
Is it possible the toggle switch is dead on arrival? Could the fuse be dead although it looks good?
The Greatest Moderator on The Internet
Did you check your connections and your fuse with a test light to make sure you have power?
If you can't get it figured out let Paul know and I'm sure he will take care of any problem that you may have.
Best of Luck!
Mike U.
1 - 3 of 3 Posts
