1 - 9 of 9 Posts
I have been looking for quite some time for something other than the stock levers for the 08 and newer Road Glides. Every since they changed the lever design in 08 there is little to no aftermarkets. Have seen the Kuryakyn and PYO and that is it, other than black Harley ones, just wondered if there is a secret web site out there I am missing.
Sure is (but I can't tell you about it).
J/K you LPFRAY :D. Honestly, I don't know either but at least your post gets a bump.
Discussion Starter · #6 ·
Thanks Mass, but those are all basic I was hoping to find something a little like the Pro-one, I do have a set of grips from Joker machine, great guys and good customer service.
www.pro-one.com/Billet_Blade_Levers_s/288.htm
Thanks for the inputs and the search continues. What is it they say if you can't find it make it yourself.
Discussion Starter · #7 ·
Just a refresh to see if anything is out there. I am looking at the PYO black for the 08 and newer baggers.
Can someone confirm that the difference between the newer touring levers and the old is the neutral safety tab on the levers? In other words IF you use an older lever, you would only be able to start the bike in neutral. I also am a fan of the Pro Ones but also unsure where to find levers. searched on EBay using various keywords and found great results, but mostly up to 2007 touring. only found basic levers for 08-10 Touring.
1 - 9 of 9 Posts
