Ok question is if I am running my stock HU on my 2013 RGU do I need line levelers or are they for the 2014 and newer bikes?
I am running straight to the amp and things sound ok. But just double checking myself since I read on here and others about using them.
If I remember right I don't but that's why I am asking :smile:
Yes, I know change the HU to an aftermarket. It may happen just like the headset for the long trip with the wife.
And I gain bluetooth with an aftermarket radio and they make bluetooth headsets but a phone only gonna connect to one or the other so ya gotta pick.
Thanks for the replies
Drifter
I had to use it on my 16 and 17, but on the 10 I didn’t. I eventually went to one on the 10 when I changed the HU, then I bought one off eBay for around $10, works perfect. I was told the same one wouldn’t work on the newer bikes........
Line levelers are only used on 14+ bikes. Depending an the aftermarket HU and amp combo, some 13 and down bikes may use a line out converter. The converter and leveler are not typically interchangeable.
On my 13 my first audio upgrade was a RF pbr300 amp and Hertz speakers...no line leveler.
A couple months later I added the Aquatic AQ-MP-5UBT-H head unit...great upgrade btw...still no line leveler.
On my 17 my first upgrade is Diamond amp and DD speakers...they recommended a line leveler so had one installed.
Hope this helps
The BT 355 line leveler is for 2014 and newer HD's.
The 2013 and earlier HD's DO NOT require a BT 355 Line Leveler.
If your new Amp for your 2013 and earlier does not have a Hi Level Input (signal from the Factory speaker wires to the amp) Then a inexpensive line out converter can be used to convert the signal from the speakers to a low level signal input.
@sloride hey brother, nice to see you are still with the living.
Hope the silly season isnt geting too silly for you.
Mike
Thanks for the replies everyone.
That was what I was thinking no need for the 13 and down bikes.
Merry Christmas and a Happy New Year
Drifter
For what its worth, the folks at Soundz, highly regarded audio shop recommends against a line leveler, instead they recommend flashing the unit to flatten the EQ curve. I'm not an expert, nor have I even slept at a Holiday Inn, but just passing this along.
