2008-2012, chrome fairing support mounts/brackets that attach to the crash bars, need left and right.
Updating 2000 Roadglide to newer bullet style front turn signals, I need the newer style fairing mount.
Just so you know, the small clamp section of the mounts are the expensive parts for what they are but luckily you allready have them. The neck mount will also require changing. Check out Pc PaiN on this site for a quote.
RT
I'm not sure why the early mounts won't work, you should just have to remove the stud plate & cover plate that goes through the 2 mounting holes in the fairing. That's after you've removed the original turns. That's what it looks like to me after looking at a parts breakdown for a 00 RG.
The Fairing mounts (58454-04) and "C" clamp (58487-04) used 2004-2009 will work with your Fairing mount.
But the mounts for 2010-up (58454-10-left, 58460-10-right) will require a change the the newer reangled mounts (58530-10,Fairing mount bracket).
Correct. It is related to the geometry of the fairing. The angle was changed on 04. The angle and height was the most recent model years.
RT
My mounts will work however there a bloody great hole where the 2000 pancake signal mounts to them, not too cool looking
But the mounts for 2010-up (58454-10-left, 58460-10-right) will require a change the the newer reangled mounts (58530-10,Faoring mount bracket).
Thanks for taking the time to share those numbers with me, I really appreciate it.
Missed a great deal on e bay today, I was hoping someone on here did a custom job and had these parts laying around collecting dust.
