1 - 2 of 2 Posts
All these parts are for 103 and 110 twin cam engines
1- SE 58mm throttle body p/n29667-07
2- SE pro high flow injectors 5.3 GPS p/n27796-08
3- SE 255 cams used
4 - SE 259E cams like new
5- V&H big shot true duals with quite baffles If you want a loud bike these will meet the requirements. Pipes are used and there are blems on heat shields. and they use 18mm 02 sensors
Also Hayden primary chain tensioner used
Just seeing if there is any interest in these parts, if there is interest I'll take the parts to SW that have interest.
I'm not selling on the forum so no pics as of now.
That's all for now but I'll go through all my parts and see what else I want to get rid of.
Discussion Starter · #2 ·
The SE 259E cam can be used with any twin cam engine with stock heads but you need to upgrade the valve springs because of the higher lift. This cam works best on high compression stage 3 or 4 builds and can be used on all twin cam engines up to 120 ci.
Specs
intake exhaust
.579 .579
duration 246 250
timing in degrees intake 19 BDTC/ 47 ABDC exhaust 58 BBDC/ 12 ATDC
TDC lift 0.182 .155
The reason I'm not selling on forum or any other internet form a sales is because there are too many scammers out there and I don't want to deal with shipping and I don't have Pay Pal.
Anything I don't get rid of will go to the next swap meet.
1 - 2 of 2 Posts
