1 - 3 of 3 Posts
And speedo.
I flashed a new map this morning. About 5 minutes after I left for work no dash. No gauges at all. Speedo stuck at 60. Tach at 2k.
Checked trouble codes. Lost connection between ecm. Lost connection with Speedo. I went back to my old map and was able to clear the ecm codes it won't clear the Speedo codes.
Fuse? FP3?
Discussion Starter #2
I'm not thinking the 2 are connected. When you flash the tuner I assume it throws that code. Just clear it because it's a non issue. It has not come back since I cleared it. But the Speedo won't go away. Only fuses I found was the small block on the left side. No instrument cluster fuse.
I'll check the connection under the Speedo and tach when I get home.
Try unhooking the battery or pulling the main fuse and let the bike sit for a while, doing this may clear out the DTC's that you can't clear.
1 - 3 of 3 Posts
