1 - 18 of 18 Posts
Tried to research this, can't find anything. Can ya help a idiot out?
I keep getting that code randomly on the bike. Everything checks out. Battery at 12.8. Motor running 14.6 I changed the fob batt it still does it randomly like it popped up Friday not again till today. Not sure where to start but I do have hammers... .
My low fob has suddenly popped up also. Good reminder for me to change it. Could it just be a historic code coming back up? Just a wild guess
While the bike is not running the battery should be around 13.8 . If the battery reads lower it may be time for a new battery. There is nothing wrong with your charging system because 14.6 is a sign of a healthy charging system.
Your FOB has nothing to do with the bikes battery the FOB has its own battery which should be a CR2032
Mark
Reactions: DanHappy
I always see 13.4 to 13.8 on a healthy battery when the bike is shut off. But My volt meter is a old analog so it may be off. the new digitals may be more accurate.
The volt meter on my bike which is digital always read 13.8 when running until I put all LED lights in now it reads 14.2 unless I crank the amp then it drops to 14.1 to 14.0.
Still if the OP is getting a low battery DTC then something is wrong with the battery or the connections. JMO
Mark
Reactions: MORider
How and where are you getting a F08 code?
All DTC's start with a 'U' or a 'P'.
There is a "sticky" in the electrical section that tells you how to get the codes.
Sent from my coal fired pay phone
Discussion Starter · #10 ·
It reads out on my odometer.
Just an FYI, a couple of months after I purchased my 2017 my fob battery went dead. After some complaining and another dead battery I found out (probably on this forum) that if I carry the fob in the same pocket as my car fob the battery drains. I have not had a dead battery since keeping them separate.
Also, leaving the keys in or near the bike while in the garage can drain both the bike and FOB batteries sooner since they will be "communicating" with each other. Or so I'm told.
Thanks for the heads up on that. My car and bike Fobs hang right next to each other.
Reactions: DanHappy
My 2015 RGS FOB has original battery and stays in glove box. One battery change outside the one I cooked with bad wiring changing bars. Warranty covered that one
1 - 18 of 18 Posts
