1 - 20 of 29 Posts
I'm putting the black cover kit on my M8 when ever i find a few free hours on a weekend so i just wanted to get a game plan incase i need any special tools or need to know anything
Question 1: It looks like the tank will have to come off to replace the upper box cover does it?????
Question 2 the lower box covers do i need to remove the rockers or anything else to replace the lowers???
Either way ill be pulling them off to switch to the black ones, I just like to know what im getting into before i start taking it apart.
Yes you will need to pull the tank.
Then it's the covers and the rocker arms, followed by the lowers. 8 bolts in the lowers.
You may need to pull the oil separator, not sure if it's in the way or not.
When you put the rockers back on, make sure the tappets are on base (valves closed) as you draw the shaft bolts tight. And draw them down evenly by hand. You'll also need some thread chasers to clean the old thread locker out of the bolt holes. Locktite won't hold if you don't clean the holes and bolts.
There was a real good YouTube out there that shows step by step and items to watch for. Not the M8 but sure its close.
https://www.youtube.com/watch?v=_AoAgXXfQxE
This one will give you a good idea of whats in store.
https://www.youtube.com/watch?v=8dQ1-A6Ig1w
2021 Ducati Multistrada V4S
You need to take great care and follow the manual during every step of this process if you must do this yourself. I have already heard of seasoned mechanics breaking the heads as the new design is much different than what is shown in the video's above on the TC engine. The M8 has the rocker arm shaft that goes through a molded section of the head and has a bolt that goes through it to hold it in place. This is different than the old rocker support plate that the twin cams have. If you do not follow the bolt torque sequence to the letter as well as the torque spec itself you have more than a great chance of breaking it. The only real similarity in the procedure to the twin cam is relieving the valve train pressure. If you have never worked on one of these before you may want to consider paying to have it done. That way if anything breaks, they are responsible.
I don't know what your experience level is as a mechanic, so be warned that this is not like changing the valve covers on a small block Chevy. You are not just removing a cover. It is a functional and structural part of the engine, and a screw up can cost you big time, and not covered by warranty.
My dealer told me the m8 is designed differently and the rocker arms do not need to be removed the lower covers fit around them but the rear bolts are a b**** go get to don't know for a fact but that's what I was told. Id like to know im about to do the same project.
Premium Member
dealer doesn't know what he's talking about..... (imagine that :D)
Premium Member
Yeah that's a shocker lol do you have install instructions for upper rockers and how to remove the lines over the top of them?
no problem....
The rear two bolts are difficult to get to if you don’t have the right tools.
The oil line is tricky to uninstall and install.
Manuals are not 100% accurate.
The dealer was right about taking the rocker arms off. (Gives you more room to get the lower out)
So are you saying the rockers have to or do not have to come off to get the lower off?
Premium Member
2019 RGS
Just to update this if anyone sees it.
Yes. Tank off.
No. You do not need to remove your rockers and pushrods on an M8 motor to do the bottom rocker box. I just did mine. It's tricky but you'll need to rotate the motor so that the rocker arms move into a position that allows the bottom box to come off. Ask @crazy4ink He helped me on this one.
Grille Motor vehicle Automotive tire Hood Automotive lighting
Tire Wheel Fuel tank Motorcycle Plant
Automotive tire Automotive lighting Hood Vehicle Motor vehicle
Automotive tire Motor vehicle Automotive design Automotive fuel system Automotive exterior
Yes. Tank off.
This right here. I pulled mine off a few weeks ago for a winter tear down and did the same thing. Did you have to loosen your cooling lines at all? I already had mine removed
Premium Member
2019 RGS
Those over the rockerbox oil lines were the biggest PITA of the job. I had to call crazy4ink for advice on this job. Was not a simple task. But a worthwhile one for sure.
2021 RGS 128
The oil line is a Bit*^ and getting to the bolts on the front oil line sucks because the frame is kinda in the way. The valve cover (upper) bolts on the rear cylinder suck if you don't have the right tools. You could potentially rotate the motor over til one of the valves is full open to make clearance for lower rocker to come off. Otherwise the top valve spring retainers and springs themselves get in the way. Its not a HARD job per say, just annoying. ALSO, be very careful installing the new ones as its super easy to scratch them. (ask me how I know)
At least that makes 3 cats I can drop a PM to when the time comes...LOL
Premium Member
2019 RGS
4. I did mine too. Lol. And yep it’s tedious. But worth it.
I was given a tip. Only undo the front oil line. Take off the oils fill cap and blow air through the front oil line clearing all the oil out. Otherwise you’ll have a hell of a mess. Ask me how I know that. Lol.
1 - 20 of 29 Posts
