1 - 4 of 4 Posts
Does anyone make a lowering kit that will work with Progressive 940 rear shocks? Not having an issue due to lack of height just wanting to give the bike a more raked look.
Any of the lowering kit's that work for oem shocks should work with the 944's
I would have thought that also but I read the description on a couple different kits and they both said for use with factory Harley air shocks only. I also looked into this some time back and remember reading on a forum that the problem had something to do with the 940s having a larger diameter.
I've used lowering kits before but not on NON oem shocks, so I can't say with 100% certainty. All the kit do are move the bottom of the shock back a bit.I would think if it fits in the oem spot it will fit in the lowering kit .
1 - 4 of 4 Posts
