My m8 rgs 2018 stage 4 all SE with auto tune. Pings & detonates went it gets up to running temp no one here can fix it . I see on other site it say bike not retarding when it get to 200 degrees can anyone help . Heres screen shot of other forum, this is what my bike is doing.How do is fix this problem. 60k au $ bike in garage and I cant ride for more then 50ks.
Saw a post on another forum that said he discovered that his knock sensors had not been connected during manufacturing.
Since you have a Stage 4 its probably not a factory issue, but maybe they failed to reconnect the knock sensor when they did the work, and/or its bad?
Spend some time with your bike.... look around the engine, underneath and all, and touch every electrical connection you see. Pull the air cleaner/back plate off and check around for loose mounting screws, hoses, plugs, etc. Check O2 sensor wires. Look at everything you can get to. Best of luck bro and keep us posted.
My bud got a 2019 117 stage 4 . No problems at all. He even was riding in high 90's temp.
I'd be checking for what was mentioned earlier. It's still under warranty, let the dealership fix it.
What are you using for a tuner? I know when I’ve done Stage 4 kits for customers and used the Street Tuner, I’ve increased the VE table values to help curb temps. As has been said, I would take it back to the dealership that installed the kit and have them go back over their work.
Its a tuning issue, back some spark out at operating temperature.
If its got a SE tuner on it, make sure it has the latest map installed.
