What setting do you use with your Magic Strobe?
  • Pattern 0
    Votes: 2 11.1%
  • Pattern 1
    Votes: 2 11.1%
  • Pattern 2
    Votes: 0 0.0%
  • Pattern 3
    Votes: 0 0.0%
  • Pattern 4
    Votes: 3 16.7%
  • Pattern 5
    Votes: 2 11.1%
  • Pattern 6
    Votes: 3 16.7%
  • Pattern 7
    Votes: 1 5.6%
  • Pattern 8
    Votes: 3 16.7%
  • Pattern 9
    Votes: 2 11.1%
  • Total voters
    18
1 - 11 of 11 Posts
What setting did you finally settle on?
PLEASE answer in POLL
Pattern 0: Four Flashes then Solid (Incandescent or LED)
Pattern 1: Four Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 2: Seven Flashes then Solid (Incandescent or LED)
Pattern 3: Seven Flashes, Solid for 3 Seconds, Repeat (Incandescent or LED)
Pattern 4: Quad Strobe, then Solid for 1 Second then Quad Strobe (LED Only)
Pattern 5: Quad Strobe, Solid for 1 Second, then Quad Strobe, Solid for 3 Seconds, Repeat (LED Only)
Pattern 6: Custom LED Blaster X Cycle for 3 seconds, then Solid (LED Only)
Pattern 7: Custom LED Blaster X Cycle, Repeat (LED Only)
Pattern 8: Max Strobe 4 Seconds, Solid (LED Only)
Pattern 9: Constant Max Strobe Pattern (LED Only)
I believe I am on #8 with Fillerz and a NAMZ wiring harness to my tour Pak for strobes there as well.
The wife says it could cause a seizure
#8 - Max strobe for a bit and then solid. Good thing is you can change it very easily.
Mine is a Bright Ass Light but basically pattern 4.
Interesting, I took the options right off their website?? How old is the unit, maybe they've changed the patterns available?
- Dave
Just hooked up the new magic strobe. The new one is very different from the old one. I have the hd lower 3rd run/brake light and mine set on 6. Flashes 3 times, pause, flash 3 times and then go solid.
For mine, I don't see my pattern listed either. I did a combination between the fillerz and the tour pack. The fillerz and brake light are the blaster x pattern that goes for 7 seconds, then solid. I wanted to get their attention but not cause a seizure. On the tour pack, I went with the 4 flash then solid for 3 seconds, then repeat. Two different patterns on two different parts of the bike.
I decided on the 7 second blaster then solid so that I could always start the pattern over if needed. If no one is behind me at a red light, then a car comes up, I'll let go and reapply the brake to start the pattern over. It flashes while they come to a stop, then it's solid while they're sitting behind me.
Here's a link to what mine look like. https://youtu.be/-8dputBiTD8
1 - 11 of 11 Posts
