1 - 2 of 2 Posts
I bought these lowers from Mutazo...I then purchased the Quick Release from Harley. I put them on the best I could and they seem to be a little loose. They (The lower fairings slide from left to right). Anyone else have this problem? and if so how to correct it. They match perfect with my matte black.:confused:
I had the same issue with these and all I did was use foam that has 3m tape on one side and stick them on the point of the lower fairing that hits the crash bar and tried again ...it worked perfect...did the same to one of my buddys bike and had no issue...its hidden so you don't see it...I did find that their quick release system seems to back off quite often so I would keep an eye on that...hope this helps
1 - 2 of 2 Posts
