I have never heard of that oil, I do know there are a lot of good oil products that are made by different manufacturers. Just some info for you I had a friend that put 40,000 mile on a softail he had within the two-year warranty. The bottom of the engine just flat out gave up and they Harley requested it to be sent back to them so they could figure out what happened. One of the things they also did with that engine is they verified what oil that was in the engine was the proper type of oil, spec wise, required by Harley. He uses Harley oil so that was no problem. The dealer told him that when something like that happens, Harley will check to ensure the oil meets their specs. In the scheme of things, it is not very often that a Harley engine just comes apart like that.
Just a suggestion, make sure whichever oil you use, it meets Harley's specs if it is under warranty. Just my opinion
