Metra Antenna Install Advice
I am going to be replacing the factory antenna with the Metra under the fairing on my 2010 RG.
Where is the best place to mount the antenna?
As far as power I was told to tap off of the lighter, does anyone have a suggestion for a grounding point?
Thank you​
Can one of you provide some more detail on the Mentra antenna (product/model number)? A photo of the install would be cool too. Thanks!
I went with Metra Deluxe Universal Amplified Antenna (P/N CK-UA200), it looks just like the HD antenna less the HD logo. I was able to get power from the red capped connector (if I remember correctly I believe the wire was orange with a white stripe) which is located approximately 4" down below the left side connector of the radio when facing the front of the bike. See the link below for pics.
http://www.roadglide.org/search.php?searchid=574574
