1 - 4 of 4 Posts
OK question for you fuel management guys.
My Shark: 15, 103, Screaming eagle Ventalator Elite A/C, Decatted headpipe, closed end cap Supertrapps.
My problem: Too much heat, decel pop.
I already know I need to fatten up the A/F ratio. I have no intention of doing any other mods(cams etc) so cost/performance standpoint, am I better off going with say, a FuelMoto Micro Tuner, ordo I still need to go with a PC5 or PV or one of the other expensive tuners?
As a side question, what are the differences between the $200 one vs the $500 one?
Any and all help is greatly appreciated.
TIA,
Mike
TIA,
Mike
Whatever you do don't get a FP3. You won't be able to do anything and pretty much waste your money once you do cams. Even a stage one I feel like you're leaving numbers off the table
Power Vision if you are limited to options from FuelMoto. I use TTS personally, but you'd have to source one elsewhere. Whatever you do, use a flash tuner. Don't waste your time with a harness box.
OK so I am fuel management ignorant. Whats the difference between a flash tuner and a harness box?
Also why not the FP3?
TIA
Mike
1 - 4 of 4 Posts
