1 - 1 of 1 Posts
I put this on the website that I purchased the kit from, but it did not get published. I wanted to share here just as a heads up.
I wanted to extend the wires as I was doing a handlebar change. I bought the kit because it would/should make it a little easier. Turns out I had to have a kit because I broke one of the connectors, so I was glad I ordered it. The connectors had 2 areas that was crimped. The first was the naked wire to the connector. Good and tight like it was supposed to be, The second was the 2 "fingers" that wrapped around the wire at the end, around the whole wire. This was not crimped and would not let it go through the plastic connector. I had to re-crimp every one just to be able to put the connectors together.
sorry for the windbag approach.
immo
1 - 1 of 1 Posts
