Two up front and two in the the rear.How many speakers did you have installed and where??
Yeah they should have told you, but it is pretty standard for most aftermarket installs if heating the pod up doesn’t work! Now if they didn’t put any sound deadner To cover hole, then this is why it sounds bad. They have to cover that up for the pod to give correct volume for the speaker to perform.The CVO Boom Audio had much more bass. I spoke with the installing company (this is their primary business) an they said they would open up the fairing and try some adjustments. Not sure what that means ?? I plan to have them explain why they didn't tell me they would have to cut into the speaker boxes to clear the magnets.
Do not have either !!!You will never get the best sound out of the HD head unit. Besides flashing the unit and having an amp, do you have any kind of equalizer or processor?
Bingo.......wattage may vary on the Amp but an Amp and a DSP at leastYou really need a amp at 600w and a DSP to get good sound
Are you running a DSP on your system?Bingo.......wattage may vary on the Amp but an Amp and a DSP at least
Si SeniorAre you running a DSP on your system?
