Monroe air shocks
426K views 1.2K replies 138 participants last post by  dmdsr
#1 ·
Has anyone done the DIY air ride system with the corvette shocks. I am seeing a lot of other forums talking about this and getting it done for around $250. Any input from anyone.
#942 ·
Roadie in need of help
Ok fella's! finished the monroe air mod...put in energy suspension bushings..first time out today in MN windy as He77....had to ride at least 110 PSI to reduce bottoming out.....with wife on my 2011 RG Custom.
I'm 170lb wife is 110 lb.....not having good luck here... vibrates like a bastard at 80 PSI and under alone or with wife on back...Viair 0-160 gauge terrible to read going down the road jumps anywhere from 80-120 psi depending on speed this is the second gauge gauge Viair has sent me.....going to pick up a liquid filled or a digital gauge. the up side is the ride is much better with the wife on at highway speeds and 110+ psi...( maybe the gauge is so friggin off that i dont really know where i'm at for psi hell at this point i could be at 50psi.
Any help on the shake and juttering?......i am running 1" lowering blocks not sure if this would effect the ride or not but going to pull them tomorrow and see if that helps. factory rear wheel and rubber and a 21" up front..I put in Progressive monotubes -2" I always use factory torque values. Man am i frustrated!!:confused:
#945 ·
for those that have done this, what is the size of bolt that i need for the shocks?
i think that some one posted that, but i cant find where.
Ive got everything but the shocks, will get those today and should have this on by the weekend.
#950 ·
Can someone please PM me the part numbers needed from fastenol for the set up?
Not sure about that company but if get on Amazon and search for the viair compressor you'll see basically everything everyone else used in the "customers also bought" section on the page. You can use that until you get the part numbers from someone
#951 ·
Has anyone ever managed to use a latching relay with a digitally set pressure sensor so a momentary button will air the DIY system up to a set PSI automatically? I don't want to have to hold the button and I want to set it up with a 2 button wireless switch. It should be wired so one push of a button and it will air up to it's preset level automatically.
#954 ·
Not particuarly, but I do know that Ride Rite airbags company has a system they sell for about $500.00 or something like that comes with a small similar viair compressor and electronic setup that is wireless and can be preset.
I'm actually thinking about getting this for my truck when towing.
#957 ·
There's are several aftermarket shocks available that are better than the stock shocks. You have to remember that this is a Do It Yourself air shock setup. Again there are better or more expensive systems available. For the time and money I think it was worth it for me to do. As far as being short all i can say is when it's full compressed the shocks are only about 9" which would basically be riding a rigid hardtail. Some people put limiting straps on to prevent it from going to full extention which is about 14". As far as comfort I'd say theyes are about on par with the stock shocks but really shine when you have weight on the bike. Without actually doing this yourself you'll never be able to know for sure if it's for you or not.
#959 ·
I would imagine if you put the straps on them at whatever height you want then basically you'll be able to keep it at that height and fill the shock to whatever pressure you need to keep from bottoming out. The straps can be made at your local hardware store for a couple bucks. I had a set made but havent put them on yet
#972 ·
I've been having problems with the Monroe's leaking at the top around where the eye is welded on. This is the second set that has done that. I wonder if the limiting straps are putting excess stress on the shock?
#962 ·
Gabriel vs Monroe
I've read most of this forum. What are ya'lls thoughts on the Gabriel air shocks? I had the Monroe max air on my bike and 1 got a leak. Monroe are on back order and they only go up to 150 psi. I have an 18 on the rear so I have to run more air to keep from rubbing on bumps. So I got the Gabriels cause they go up to 200psi. To me they don't ride as good as the Monroes. seems as if they are ruffer and seems like they have to have more air. Has any one else had both?
#964 ·
I had the same experience with the Gabriel's over the Monroe's. I like the Monroe's better
#969 ·
Does anyone else have the issue of the monroes leaking off? I had the gabriels and they didn't leak off at all. I put the monroes back on and have noticed they tend to leak off and it is a brand new set.
I never tried the Gabriels so I can't comment on them. I have the Monroes and I haven't had any problems with them leaking down. Maybe check the fittings. If you're using the stock air fitting on the monroes make sure you have the tiny o-ring in place and the cap is screwed down tight not just snug. Fill a spray bottle with soapy water and give them a good soaking to see where on the shock it's leaking from. While you're at it spray all the air line connections you have to be sure it isn't in of those leaking
